[Qgis-developer] Processing causes major slowness at QGIS startup
Paolo Cavallini
cavallini at faunalia.it
Wed Aug 27 00:23:47 PDT 2014
Il 27/08/2014 08:36, Luca Manganelli ha scritto:
> On Wed, Aug 27, 2014 at 7:43 AM, Martin Dobias <wonder.sk at gmail.com> wrote:
>> Actually since the adoption of metadata.txt for plugin metadata it is
>> not necessary for QGIS to load all python plugins on start up. I have
>> a suspicion that it is the plugin installer component which tries to
>> load them while QGIS is being started (just to check whether they load
>> correctly). Such check is IMHO not necessary and its removal would
>> make the loading time shorter.
> +1 for me :-) fixing this problem could be a big improvement in startup time!
I have seen plugins occasionally getting broken: are you suggesting to do the check
only on activating them (+ at install time of course)?
All the best.
Paolo Cavallini - www.faunalia.eu
Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
