[Qgis-developer] Processing causes major slowness at QGIS startup
Luca Manganelli luca76 at gmail.com
Wed Aug 27 00:37:34 PDT 2014
On Wed, Aug 27, 2014 at 9:23 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> I have seen plugins occasionally getting broken: are you suggesting to do the check
> only on activating them (+ at install time of course)?
> All the best.
No. As Martin Dobian suggested, when QGIS is loading, only the
"metadata.txt" file of each plugin should be read without executing
the Init() function of *every* (enabled and not enabled) plugin.
