[Qgis-developer] line renderer and composition mode
Andrea Peri
aperi2007 at gmail.com
Wed Aug 27 07:22:10 PDT 2014
style -> advanced -> symbol-level.
A.
2014-08-27 16:20 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> Your solution is not always good.
> You should could use the level symbols to give what symbol won in overlap.
> A.
> 2014-08-27 14:53 GMT+02:00 Jürgen E. <jef at norbit.de>:
>> Hi,
>> any objections to have the line symbol layer render in composition mode
>> "source"?
>> I have a layer with multiple levels of administrative boundaries, where higher
>> level boundaries (eg. state) lie over lower level boundaries (county). Lower
>> level boundaries should not be visible if there is a higher level boundary on
>> top of them. The styles are dash-dotted - so the lines don't fully cover the
>> lines below.
>> I could solve that by putting a white line on the bottom of the symbol, but
>> that would also mean that layers below are covered, that I still would like
>> see.
>> Rendering the line in "source" composition would allow to have a fully
>> transparent line symbol layers on the bottom of the symbol that would overwrite
>> the already rendered lines on that layer with transparency.
>> Is that already possible in a different way (without resorting to multiple
>> vector layers) to achieve the same? Or does it introduce some problem that I
>> didn't think of? It could still be optional...
>> Jürgen
>> diff --git a/src/core/symbology-ng/qgslinesymbollayerv2.cpp b/src/core/symbology-ng/qgslinesymbollayerv2.cpp
>> index 5a06f23..e21474a 100644
>> --- a/src/core/symbology-ng/qgslinesymbollayerv2.cpp
>> +++ b/src/core/symbology-ng/qgslinesymbollayerv2.cpp
>> @@ -207,10 +207,12 @@ void QgsSimpleLineSymbolLayerV2::renderPolygonOutline( const QPolygonF& points,
>> return;
>> + p->save();
>> + p->setCompositionMode( QPainter::CompositionMode_Source );
>> if ( mDrawInsidePolygon )
>> //only drawing the line on the interior of the polygon, so set clip path for painter
>> - p->save();
>> QPainterPath clipPath;
>> clipPath.addPolygon( points );
>> @@ -236,11 +238,8 @@ void QgsSimpleLineSymbolLayerV2::renderPolygonOutline( const QPolygonF& points,
>> renderPolyline( ring, context );
>> - if ( mDrawInsidePolygon )
>> - //restore painter to reset clip path
>> - p->restore();
>> + //restore painter's composition mode and reset clip path
>> + p->restore();
>> @@ -252,6 +251,9 @@ void QgsSimpleLineSymbolLayerV2::renderPolyline( const QPolygonF& points, QgsSym
>> return;
>> + p->save();
>> double offset = 0.0;
>> applyDataDefinedSymbology( context, mPen, mSelPen, offset );
>> @@ -280,6 +282,8 @@ void QgsSimpleLineSymbolLayerV2::renderPolyline( const QPolygonF& points, QgsSym
>> for ( int part = 0; part < mline.count(); ++part )
>> p->drawPolyline( mline[ part ] );
>> + p->restore();
>> QgsStringMap QgsSimpleLineSymbolLayerV2::properties() const
>> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
>> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
>> Software Engineer D-26506 Norden http://www.norbit.de
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.9 (GNU/Linux)
>> iD8DBQFT/dS6c/GhTF5ESHURAk2fAJ4jTVoeU69IRlX2TPOzrL5KZGSeGACgs7gP
>> yPIP/+rhT1MnuZypz3l/OzM=
>> =0y5K
>> -----END PGP SIGNATURE-----
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
