[Qgis-developer] line renderer and composition mode
Jürgen E. Fischer
jef at norbit.de
Wed Aug 27 08:05:39 PDT 2014
Hi Andrea,
On Wed, 27. Aug 2014 at 16:20:14 +0200, Andrea Peri wrote:
> Your solution is not always good.
> You should could use the level symbols to give what symbol won in overlap.
I'm already using symbol levels. Is there a way to have transparency in higher
levels remove earlier rendered stuff on lower levels?
Level 2 - .. -
Level 1 -.-.-.
Should look like
if there are level 1 & 2 boundaries on top of each other and not like
Still the transparent bits should not cover (vector/raster) layers below.
Putting a fully transparent line on the bottom of each level and rendering it
in source composition mode would achieve that (ie. the transparent bits of the
higher level would make everything rendered in lower levels transparent again
instead of leaving it as is).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140827/5cb627ea/attachment.pgp>
