[Qgis-developer] line renderer and composition mode
Andrea Peri
aperi2007 at gmail.com
Wed Aug 27 08:09:44 PDT 2014
Yes.
You can apply the transparency on color single.
Il 27/ago/2014 17:06 "Jürgen E." <jef at norbit.de> ha scritto:
> Hi Andrea,
> On Wed, 27. Aug 2014 at 16:20:14 +0200, Andrea Peri wrote:
> > Your solution is not always good.
> > You should could use the level symbols to give what symbol won in
> overlap.
> I'm already using symbol levels. Is there a way to have transparency in
> higher
> levels remove earlier rendered stuff on lower levels?
> Level 2 - .. -
> Level 1 -.-.-.
> Should look like
> if there are level 1 & 2 boundaries on top of each other and not like
> Still the transparent bits should not cover (vector/raster) layers below.
> Putting a fully transparent line on the bottom of each level and rendering
> it
> in source composition mode would achieve that (ie. the transparent bits of
> the
> higher level would make everything rendered in lower levels transparent
> again
> instead of leaving it as is).
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> iD8DBQFT/fPDc/GhTF5ESHURAnUNAJ9JoQRZNHxxjNe/YL7BLIz+99mYbwCfXbce
> 462gR50pZLQquO+6SWVpkl8=
> =6RD6
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140827/f97f297c/attachment.html>
