[Qgis-developer] Core dump when starting QGIS
Andreas Neumann
a.neumann at carto.net
Mon Dec 1 02:25:24 PST 2014
With the newest commit it works fine. Apparently there was an issue with
the browser dock startup which made QGIS crash on startup. Now it works
fine.
Thanks,
Andreas
On 01.12.2014 08:50, Alessandro Pasotti wrote:
> Hi,
> the same happened to me yesterday when upgrading from 12.04 to 14.04.
> When I launched QGIS the second time it ran without errors.
> 2014-12-01 8:04 GMT+01:00 Andreas Neumann <a.neumann at carto.net>:
>> Hi,
>> I recently upgraded from Kubuntu 14.04 to 14.10. With the current master I
>> get a core dump when starting QGIS. I removed the build directory and
>> recreated the settings with ccmake. The compile works fine but when I start
>> QGIS I get a core dump. Here are the startup messages:
>> Warning: loading of qt translation failed
>> [/usr/share/qt4/translations/qt_en_US]
>> Warning: Bus::open: Can not get ibus-daemon's address.
>> IBusInputContext::createInputContext: no connection to ibus-daemon
>> Warning: QGraphicsScene::addItem: item has already been added to this scene
>> QGIS died on signal 11Could not attach to process. If your uid matches the
>> uid of the target
>> process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try
>> again as the root user. For more details, see /etc/sysctl.d/10-ptrace.conf
>> ptrace: Operation not permitted.
>> No thread selected
>> No stack.
>> gdb returned 0
>> Aborted (core dumped)
>> I see the splash screen and immediately get a core dump. I don't even see
>> the main application window.
>> I wonder if there is a library problem after my Ubuntu update?
>> Thank you if you have any idea what I could do to solve my problem.
>> Andreas
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
