[Qgis-developer] Core dump when starting QGIS
Mikhail Tchernychev
misha at mail.geometrics.com
Mon Dec 1 10:12:47 PST 2014
This has been reported as http://hub.qgis.org/issues/11716
Apparently there is not yet update for ubuntugis-nightly :(
But there is always hope :)
Best Regards
Mikhail
On 12/1/2014 2:25 AM, Andreas Neumann wrote:
> Hi,
> With the newest commit it works fine. Apparently there was an issue
> with the browser dock startup which made QGIS crash on startup. Now it
> works fine.
> Thanks,
> Andreas
> On 01.12.2014 08:50, Alessandro Pasotti wrote:
>> Hi,
>> the same happened to me yesterday when upgrading from 12.04 to 14.04.
>> When I launched QGIS the second time it ran without errors.
>> 2014-12-01 8:04 GMT+01:00 Andreas Neumann <a.neumann at carto.net>:
>>> Hi,
>>> I recently upgraded from Kubuntu 14.04 to 14.10. With the current
>>> master I
>>> get a core dump when starting QGIS. I removed the build directory and
>>> recreated the settings with ccmake. The compile works fine but when
>>> I start
>>> QGIS I get a core dump. Here are the startup messages:
>>> Warning: loading of qt translation failed
>>> [/usr/share/qt4/translations/qt_en_US]
>>> Warning: Bus::open: Can not get ibus-daemon's address.
>>> IBusInputContext::createInputContext: no connection to ibus-daemon
>>> Warning: QGraphicsScene::addItem: item has already been added to
>>> this scene
>>> QGIS died on signal 11Could not attach to process. If your uid
>>> matches the
>>> uid of the target
>>> process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or
>>> try
>>> again as the root user. For more details, see
>>> /etc/sysctl.d/10-ptrace.conf
>>> ptrace: Operation not permitted.
>>> No thread selected
>>> No stack.
>>> gdb returned 0
>>> Aborted (core dumped)
>>> I see the splash screen and immediately get a core dump. I don't
>>> even see
>>> the main application window.
>>> I wonder if there is a library problem after my Ubuntu update?
>>> Thank you if you have any idea what I could do to solve my problem.
>>> Andreas
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
PLEASE NOTE: This message, including any attachments, may include privileged,
confidential and/or inside information. Any dissemination, distribution or copy
of this communication by anyone other than the intended recipient is strictly
prohibited. If you are not the intended recipient, please notify the sender by
replying to this message and then delete it from your system. Information
provided via electronic media is not guaranteed against defects including
translation and transmission errors. The company accepts no liability for any
damage caused by any virus transmitted by this email.
Geometrics Inc. | 2190 Fortune Drive | San Jose, CA 95131 USA
