[Qgis-developer] [QGIS-Server] Enhance http://qgis.org/wms_1_3_0.xsd and WMS 1.3.0 compliance
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Tue Dec 2 00:00:29 PST 2014
Hi René-Luc
Is the motivation behind the getSchemaExtension only to support the
additional features of QGIS server? Or is the schema extension also
important in other contexts (e.g. some inspire thing that I might not
know about)? In case the former, I'm proposing to just remove those
elements from the GetCapabilities response and only show in
GetProjectSettings. The QGIS schema was good to give people more time to
switch to newer webclient versions. However at some point there must be
a switch.
Regards,
Marco
On 01.12.2014 22:36, René-Luc Dhont wrote:
> Hi dev,
> I proposed this pull request
> https://github.com/qgis/QGIS/pull/1715
> to fix the issue 'QGIS Server getcapabilites response is not WMS
> compliant'
> http://hub.qgis.org/issues/10489
> What do you think about it ?
> René-Luc
> Le 01/12/2014 15:34, Richard Duivenvoorde a écrit :
>> On 01-12-14 14:55, René-Luc Dhont wrote:
>>> Hi dev,
>>> I would like to update http://qgis.org/wms_1_3_0.xsd to enhance
>>> QGIS-Server compliance with WMS 1.3.0.
>>> I didn't find where this file is stored and how to update it. Did
>>> someone know about its ?
>> Hi René-Luc,
>> I had a look for it, and found it. It is in the web dir of the qgis.org
>> server. There is also a 'version.txt' there (used for the url
>> http://qgis.org/version.txt in QGIS).
>> For what I know it is not available somewhere else on github or so (if
>> anybody knows: plz let me know).
>> If you sent me/us a new version (and you are sure nothing breaks for
>> other people), I'm happy to put it on the server.
>> Maybe for future it is best to put those files in Github? So we make a
>> directory 'static' in https://github.com/qgis/QGIS-Website and copy the
>> content of that directory verbatim to the html root?
>> Regards,
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
