[Qgis-developer] [QGIS-Server] Enhance http://qgis.org/wms_1_3_0.xsd and WMS 1.3.0 compliance
René-Luc Dhont rldhont at gmail.com
Tue Dec 2 00:31:38 PST 2014
Hi Marco,
Firstly I would like to update WMS 1.3.0 GetCapabilities for properly
declare the request GetLegendGraphic. This request is defined in 'Styled
Layer Descriptor profile of the Web Map Service Implementation
Specification'. One of my customer needs it to add his QGIS-Server WMS
layers in a GeOrchestra application.
Then I think it will be useful to have GetStyles in WMS 1.3.0 and not
only in WMS 1.1.1. GetStyles is the motivation behind
getSchemaExtension. The Open Geospatial Consortium gives a way to
declare extended request in WMS 1.3.0 and MapServer use it to add this
request.
Finally I think GetCapabilities is the right place to declare extended
request like GetLegendGraphic or GetStyles. GetPrint has probably to be
simplified in GetCapabilities. The extended schema is not for add all
the project settings in GetCapabilities but to decare request for
clients and other interoperable applications like GeoServer, GeoSource,
GeOrchestra, etc.
It's also a way to declare QGIS-Server extended request like :
GetProjectSettings, GetContext, etc.
Regards,
René-Luc D'Hont
3Liz
Le 02/12/2014 09:00, Marco Hugentobler a écrit :
> Hi René-Luc
> Is the motivation behind the getSchemaExtension only to support the
> additional features of QGIS server? Or is the schema extension also
> important in other contexts (e.g. some inspire thing that I might not
> know about)? In case the former, I'm proposing to just remove those
> elements from the GetCapabilities response and only show in
> GetProjectSettings. The QGIS schema was good to give people more time
> to switch to newer webclient versions. However at some point there
> must be a switch.
> Regards,
> Marco
> On 01.12.2014 22:36, René-Luc Dhont wrote:
>> Hi dev,
>> I proposed this pull request
>> https://github.com/qgis/QGIS/pull/1715
>> to fix the issue 'QGIS Server getcapabilites response is not WMS
>> compliant'
>> http://hub.qgis.org/issues/10489
>> What do you think about it ?
>> René-Luc
>> Le 01/12/2014 15:34, Richard Duivenvoorde a écrit :
>>> On 01-12-14 14:55, René-Luc Dhont wrote:
>>>> Hi dev,
>>>> I would like to update http://qgis.org/wms_1_3_0.xsd to enhance
>>>> QGIS-Server compliance with WMS 1.3.0.
>>>> I didn't find where this file is stored and how to update it. Did
>>>> someone know about its ?
>>> Hi René-Luc,
>>> I had a look for it, and found it. It is in the web dir of the qgis.org
>>> server. There is also a 'version.txt' there (used for the url
>>> http://qgis.org/version.txt in QGIS).
>>> For what I know it is not available somewhere else on github or so (if
>>> anybody knows: plz let me know).
>>> If you sent me/us a new version (and you are sure nothing breaks for
>>> other people), I'm happy to put it on the server.
>>> Maybe for future it is best to put those files in Github? So we make a
>>> directory 'static' in https://github.com/qgis/QGIS-Website and copy the
>>> content of that directory verbatim to the html root?
>>> Regards,
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
