[Qgis-developer] Cannot load python after compiling master
Mikhail Tchernychev
misha at mail.geometrics.com
Thu Dec 4 08:49:52 PST 2014
I was able to fix it by defining LD_LIBRARY_PATH to point to development
libs.
like export LD_LIBRARY_PATH=/home/misha/opt/qgis-dev/lib
Aparently there qgis tries to load libs from other places; in my case
it is probably
because I have qgis installed from repository.
Mikhail
On 12/4/2014 3:11 AM, Etienne Trimaille wrote:
> Hi,
> I've nearly the same problem on master since this week-end (I believe) :
> Couldn't load PyQGIS.
> Python support will be disabled.
> Traceback (most recent call last):
> File "", line 1, in
> File "/home/etienne/apps/share/qgis/python/qgis/__init__.py", line 36, in
> from qgis.core import QgsFeature, QgsGeometry
> File "/home/etienne/apps/share/qgis/python/qgis/core/__init__.py", line 2, in
> from qgis._core import *
> ImportError: /home/etienne/apps/share/qgis/python/qgis/_core.so: undefined symbol: _ZTV27QgsCoordinateTransformCache
> 2014-12-03 20:29 GMT+01:00 Mikhail Tchernychev
> <mikhailtchernychev at gmail.com <mailto:mikhailtchernychev at gmail.com>>:
> Hi,
> I downloaded and compiled latest git snapshot. However when I try
> to run qgis
> I am getting:
> File "", line 1, in
> File "/home/misha/opt/qgis-dev/share/qgis/python/qgis/__init__.py", line 36, in
> File "/home/misha/opt/qgis-dev/share/qgis/python/qgis/core/__init__.py", line 2, in
> ImportError: /home/misha/opt/qgis-dev/share/qgis/python/qgis/_core.so: undefined symbol: _ZTI18QgsHeatmapRenderer
> Python version:
> 2.7.6 (default, Mar 22 2014, 23:03:14)
> [GCC 4.8.2]
> QGIS version:
> 2.7.0-Master 'Master', exported
> Python path:
> ['/home/misha/opt/qgis-dev/share/qgis/python',
> u'/home/misha/.qgis2/python',
> u'/home/misha/.qgis2/python/plugins',
> '/home/misha/opt/qgis-dev/share/qgis/python/plugins',
> '/usr/lib/python2.7', '/usr/lib/python2.7/plat-i386-linux-gnu',
> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
> '/usr/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages/PILcompat',
> '/usr/lib/python2.7/dist-packages/gtk-2.0',
> '/usr/lib/pymodules/python2.7',
> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
> I suppose this should be very simple. Is some package missing?
> I have qgis installed from ubuntugis-nightly but it stopped
> working on Nov 20, and no new version
> yet available.
> This is for Ubuntu trusty 14.04
> Thank you
> Mikhail
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
PLEASE NOTE: This message, including any attachments, may include privileged,
confidential and/or inside information. Any dissemination, distribution or copy
of this communication by anyone other than the intended recipient is strictly
prohibited. If you are not the intended recipient, please notify the sender by
replying to this message and then delete it from your system. Information
provided via electronic media is not guaranteed against defects including
translation and transmission errors. The company accepts no liability for any
damage caused by any virus transmitted by this email.
Geometrics Inc. | 2190 Fortune Drive | San Jose, CA 95131 USA
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141204/fdb71423/attachment.html>
