[Qgis-developer] False failures in the testsuite
Nyall Dawson nyall.dawson at gmail.com
Thu Dec 11 10:54:56 PST 2014
On 12 Dec 2014 5:11 am, "Sandro Santilli" <strk at keybit.net> wrote:
> Once again I'm facing testsuite failures from a branch with NOTHING
> effectively changed. These are the changes in the branch:
>   https://github.com/qgis/QGIS/pull/1729/files
> As once again I cannot see what difference could my change introduce,
> can it be that the tests are suffering from some code-independent
> glitches making them unstable ? Could it maybe be threading ?
> Or unclearn builds from travis ?
Check the Travis build logs. The failure started with 7f8006f. The commit
message explains what is happening - a fix previously introduced was found
to cause some serious issues so was reverted. As a consequence the original
bug the test was designed to detect has stated failing again. It's a
correct failure, and is now waiting on me finding a better fix than the one
that was reverted...
Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141212/52694100/attachment.html>
