[Qgis-developer] EPSG codes
Trevor Wiens
tsw.web at gmail.com
Fri Dec 12 09:05:47 PST 2014
I have two debian Wheezy systems. One with 2.4 and the other with 2.6.1.
In the 2.4 instance 6148 is present and in the 2.6.1 instance it is not
Runing /usr/lib/qgis/crssync does not solve the issue. It updates various
files including
/usr/share/qgis/resources/srs.db
On the box with 2.4 there is a table called tbl_srs which has 5630 records
including one for EPSG:6148. On the 2.6.1 box this same table has 5325
records and no entry for EPSG:6148.
It is unclear which package provides this database that does seem to be the
source of the issue.
Hope that helps.
TSW
On Fri, Dec 12, 2014 at 9:12 AM, Zoltan Szecsei <zoltans at geograph.co.za>
wrote:
> On 2014/12/12 18:09, Andre Joost wrote:
>> Hmmm... I remember I got and older version when I had the ubuntugis
>>> repository, so I uninstalled that and then apt-get installed from the
>>> qgis.org repository.
>> You should look for ubuntugis-unstable, 2.6.1 is from Sun, 30 Nov 2014
>> 22:07:45 +0100
> OK - cool - thanks.
> Regards,
> Zoltan
>>> Is there a definitive list of what to install?
>>> I think I just did:
>>> python-software-properties
>>> qgis
>>> python-qgis
>> I just did sudo apt-get update and apt-get upgrade, and saw that the qgis
>> packages were held back. So I forced the install of qgis and python-qgis
>> manually, and everything worked again.
>> In Windows I know where to find the postinstall.log, I'm not sure where
>> it is logged on Ubuntu.
>> HTH,
>> André Joost
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Zoltan Szecsei PrGISc [PGP0031]
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> P.O. Box 7, Muizenberg 7950, South Africa.
> Mobile: +27-83-6004028
> Fax: +27-86-6115323 www.geograph.co.za
Trevor Wiens
Apropos Information Systems
aproposinfosystems.com
Calgary, Alberta
Ph. 403-973-5901
Fax 780-666-4580
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141212/fedad844/attachment.html>
