[Qgis-developer] EPSG codes
Andre Joost andre+joost at nurfuerspam.de
Fri Dec 12 11:33:59 PST 2014
Am 12.12.2014 um 18:05 schrieb Trevor Wiens:
> I have two debian Wheezy systems. One with 2.4 and the other with 2.6.1.
> In the 2.4 instance 6148 is present and in the 2.6.1 instance it is not
> Runing /usr/lib/qgis/crssync does not solve the issue. It updates various
> files including
> /usr/share/qgis/resources/srs.db
> On the box with 2.4 there is a table called tbl_srs which has 5630 records
> including one for EPSG:6148. On the 2.6.1 box this same table has 5325
> records and no entry for EPSG:6148.
> It is unclear which package provides this database that does seem to be the
> source of the issue.
On Windows, EPSG:6148 is defined originally in /share/gdal/compdcs.csv.
Under Ubuntu I find this file in /usr/share/gdal/1.11/.
If crssync finds this file, the definition should go into the srs.db as
well.
HTH,
André Joost
