[Qgis-developer] EPSG codes
Trevor Wiens
tsw.web at gmail.com
Fri Dec 12 12:29:19 PST 2014
On both boxes, the file compdcs.csv does not contain a record for
EPSG:6148. The gdal version is 1.9, not 1.11 for Wheezy and I assume the
same for Ubuntu.
EPSG:6148 is not listed on both boxes in any files in /usr/share/gdal/1.9/
on both of my machines (one with QGIS 2.4 listing 6148, one with QGIS 2.6
not listing 6148)
It would seem if crssync uses the files in /usr/share/gdal/1.9/ to create
srs.db it accesses other files as well because on the box with 2.4 there is
a record for EPSG:6148 and on the box with 2.6.1 there isn't.
TSW
On Fri, Dec 12, 2014 at 12:33 PM, Andre Joost <andre+joost at nurfuerspam.de>
wrote:
> Am 12.12.2014 um 18:05 schrieb Trevor Wiens:
>> I have two debian Wheezy systems. One with 2.4 and the other with 2.6.1.
>> In the 2.4 instance 6148 is present and in the 2.6.1 instance it is not
>> Runing /usr/lib/qgis/crssync does not solve the issue. It updates various
>> files including
>> /usr/share/qgis/resources/srs.db
>> On the box with 2.4 there is a table called tbl_srs which has 5630 records
>> including one for EPSG:6148. On the 2.6.1 box this same table has 5325
>> records and no entry for EPSG:6148.
>> It is unclear which package provides this database that does seem to be
>> the
>> source of the issue.
> On Windows, EPSG:6148 is defined originally in /share/gdal/compdcs.csv.
> Under Ubuntu I find this file in /usr/share/gdal/1.11/.
> If crssync finds this file, the definition should go into the srs.db as
> well.
> HTH,
> André Joost
> Qgis-developer mailing list
Trevor Wiens
Apropos Information Systems
aproposinfosystems.com
Calgary, Alberta
Ph. 403-973-5901
Fax 780-666-4580
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141212/21e5e13a/attachment.html>
