[Qgis-developer] Snapping tolerance
Matthias Kuhn
matthias.kuhn at gmx.ch
Fri Dec 12 23:35:37 PST 2014
+1 for map units. Makes much more sense to me and should confuse less.
On 12/13/2014 07:04 AM, Nathan Woodrow wrote:
> I think using the projects units makes more sense, Using the layer
> units makes things confusing I think, think of having one layer in
> degrees and another in meters.
> So +1 for swapping to mean project units.
> On Sat Dec 13 2014 at 4:02:10 PM Martin Dobias <wonder.sk at gmail.com
> <mailto:wonder.sk at gmail.com>> wrote:
> Hi
> Recently I have been working on some snapping improvements (more
> about that later) and I have found one slightly surprising thing
> about the configuration of tolerances: if the tolerance unit is
> set to "map units", it actually means "layer units" - i.e. units
> in layer's CRS and not in project's CRS. Recently there was even a
> bug report filed for that: https://hub.qgis.org/issues/11634
> I would like to change the behavior so that the "map units" in
> snapping config dialog would mean units in project's CRS. Would
> there be any objections?
> Alternatively we could just rename "map units" to "layer units" to
> make it less surprising (and eventually add a third option to use
> project's units).
> Cheers
> Martin
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141213/014e08bb/attachment.html>
