[Qgis-developer] Snapping tolerance
Zoltan Szecsei
zoltans at geograph.co.za
Sat Dec 13 03:23:45 PST 2014
+1 for renaming current snapping behaviour to "Layer Units" AND adding a
global snapping-unit option, _perhaps_ as default option.
You very often want to snap in linear units regardless of layer CRS, so
a possibility for doing that globally would be good.
Maybe if this option is chosen, it calls a subroutine to convert this
linear unit into "Layer Units" and populates the "Snapping and
Digitising Option" table for the user, in the layer units.
Regards,
Zoltan
On 2014/12/13 08:02, Martin Dobias wrote:
> Hi
> Recently I have been working on some snapping improvements (more about
> that later) and I have found one slightly surprising thing about the
> configuration of tolerances: if the tolerance unit is set to "map
> units", it actually means "layer units" - i.e. units in layer's CRS
> and not in project's CRS. Recently there was even a bug report filed
> for that: https://hub.qgis.org/issues/11634
> I would like to change the behavior so that the "map units" in
> snapping config dialog would mean units in project's CRS. Would there
> be any objections?
> Alternatively we could just rename "map units" to "layer units" to
> make it less surprising (and eventually add a third option to use
> project's units).
> Cheers
> Martin
> Qgis-developer mailing list
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax: +27-86-6115323www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141213/a7ae0294/attachment.html>
