[Qgis-developer] Snapping tolerance
Ramon Andiñach custard at westnet.com.au
Sat Dec 13 13:25:11 PST 2014
On 13/12/2014, at 14:02 , Martin Dobias wrote:
> Hi
> Recently I have been working on some snapping improvements (more about that later) and I have found one slightly surprising thing about the configuration of tolerances: if the tolerance unit is set to "map units", it actually means "layer units" - i.e. units in layer's CRS and not in project's CRS. Recently there was even a bug report filed for that: https://hub.qgis.org/issues/11634
> I would like to change the behavior so that the "map units" in snapping config dialog would mean units in project's CRS. Would there be any objections?
> Alternatively we could just rename "map units" to "layer units" to make it less surprising (and eventually add a third option to use project's units).
This explains many things, and probably a lot about why I've learnt not to entirely trust map unit snapping.
As someone that routinely works with layers in about 3 projections at the same time, could we have both "layer units" and "map units"?
-ramon.
