Can I start qgis with no python support even if it is compiled in ? I'd use it to reduce load while running under valgrind... To the same extent, can it be started with no plugins from an environment variable or similar? --strk; () ASCII ribbon campaign -- Keep it simple ! /\ http://strk.keybit.net/rants/ascii_mails.txt
