[Qgis-developer] Can qgis be started with python disabled ?
Alex Mandel
tech_dev at wildintellect.com
Wed Dec 17 11:48:02 PST 2014
On 12/16/2014 10:30 AM, Sandro Santilli wrote:
> Can I start qgis with no python support even if it is compiled in ?
> I'd use it to reduce load while running under valgrind...
> To the same extent, can it be started with no plugins from an environment
> variable or similar?
> --strk;
> () ASCII ribbon campaign -- Keep it simple !
> /\ http://strk.keybit.net/rants/ascii_mails.txt
> Qgis-developer mailing list
qgis --no-plugins
Not exactly no python, but should load faster.
-Alex
