[Qgis-developer] Custom "Identify Results" Window
Josua S
josh-talk at hotmail.com
Mon Feb 10 05:52:55 PST 2014
Hello Denis
Thanks, that's a good point. However I have several layers and in each layer several features to be identified.
Josua
> Date: Mon, 10 Feb 2014 14:46:46 +0100
> From: denis.rouzaud at gmail.com
> To: josh-talk at hotmail.com; qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] Custom "Identify Results" Window
> Hi,
> Also, I don't know if you know the "Layer selection" mode for
> identification.
> When you identify in the map, you have a contextual menu which let you
> choose which layer will be identified. Though it solves this problem
> only if the features identified were not in the same layer,
> Cheers,
> Denis
> On 10. 02. 14 14:29, Josua S wrote:
>> Hello
>> I am working on a QGIS Plugin with a touch-optimized GUI. So it is actually very useful to be able to create custom feature forms. However if I use the Identify tool and there are two or more features near together, QGIS does not show my feature form but a "Identify Results" window containing all the features nearby. So my question is: Is there a possibility to create a custom "Identify Results" window with Python if there are several features? Or is there a setting to change its behavior? Thank you very much for your help.
>> Josua
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
