[Qgis-developer] Custom "Identify Results" Window
Denis Rouzaud
denis.rouzaud at gmail.com
Mon Feb 10 05:46:46 PST 2014
Also, I don't know if you know the "Layer selection" mode for
identification.
When you identify in the map, you have a contextual menu which let you
choose which layer will be identified. Though it solves this problem
only if the features identified were not in the same layer,
Cheers,
Denis
On 10. 02. 14 14:29, Josua S wrote:
> Hello
> I am working on a QGIS Plugin with a touch-optimized GUI. So it is actually very useful to be able to create custom feature forms. However if I use the Identify tool and there are two or more features near together, QGIS does not show my feature form but a "Identify Results" window containing all the features nearby. So my question is: Is there a possibility to create a custom "Identify Results" window with Python if there are several features? Or is there a setting to change its behavior? Thank you very much for your help.
> Josua
> Qgis-developer mailing list
