[Qgis-developer] Custom "Identify Results" Window
Matthias Kuhn
matthias.kuhn at gmx.ch
Mon Feb 10 06:18:25 PST 2014
Rouzaud (2013) has a done this and published an example of a custom
identification map tool:
http://3nids.wordpress.com/2013/02/14/identify-feature-on-map/
Btw: The solution I proposed is only able to work with features on a
single layer. For multiple layer you would have to implement your own
dialog.
Matthias
On Mon 10 Feb 2014 03:11:05 PM CET, Gino Pirelli wrote:
> QgsMapTool is available in PyQGIS:
> http://www.qgis.org/en/docs/pyqgis_developer_cookbook/canvas.html#writing-custom-map-tools
> On 10 February 2014 14:49, Josua S <josh-talk at hotmail.com
> <mailto:josh-talk at hotmail.com>> wrote:
> Hello Matthias
> Thank you very much for your quick answer! I have a question left:
> Is it possible to inherit the identify maptool and use it only
> using Python? Or does this have to be done in C++?
> Josua
> > Date: Mon, 10 Feb 2014 14:39:59 +0100
> > From: matthias.kuhn at gmx.ch <mailto:matthias.kuhn at gmx.ch>
> > To: josh-talk at hotmail.com <mailto:josh-talk at hotmail.com>
> > CC: qgis-developer at lists.osgeo.org
> <mailto:qgis-developer at lists.osgeo.org>
> > Subject: Re: [Qgis-developer] Custom "Identify Results" Window
> > Hi Josua,
> > I don't think the possibility is available OOTB yet, but it
> should be
> > straightforward to create your own maptool which inherits from the
> > identify maptool and uses a QgsDualView with a request (or filter)
> > limiting the available features to only the relevant feature
> ids. This
> > should get you a list of all features and their form when selected.
> > Would be nice to be see this in core as well in the future.
> > Best
> > Matthias
> > On Mon 10 Feb 2014 02:29:37 PM CET, Josua S wrote:
> >> Hello
> >> I am working on a QGIS Plugin with a touch-optimized GUI. So it
> is actually very useful to be able to create custom feature forms.
> However if I use the Identify tool and there are two or more
> features near together, QGIS does not show my feature form but a
> "Identify Results" window containing all the features nearby. So
> my question is: Is there a possibility to create a custom
> "Identify Results" window with Python if there are several
> features? Or is there a setting to change its behavior? Thank you
> very much for your help.
> >> Josua
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> <mailto:Qgis-developer at lists.osgeo.org>
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
