[Qgis-developer] Atlas preview
Nyall Dawson
nyall.dawson at gmail.com
Wed Feb 12 11:44:05 PST 2014
On 13/02/2014 3:25 am, "Alexandre Neto" <senhor.neto at gmail.com> wrote:
> Something similar happened to me the first time I tested.
> I noticed that I needed to check the "controled by atlas" box in the map
item properties tab (this was not necessary in 2.0.1). After that,
everything worked fine.
This is needed now because more than one map can be atlas controlled (or,
potentially, no maps at all if you just want label items to change between
features). I couldn't think of any better way of exposing this to the user.
Ideas are welcome!
Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140213/290b1ac1/attachment.html>
