[Qgis-developer] Atlas preview
    Alexandre Neto
    senhor.neto at gmail.com
    Wed Feb 12 12:07:32 PST 2014
And it is a great add-on to the the atlas.
Maybe make it on by default in all maps? Or at least to the first. map
added.
We should also make it clear the in the users manual.
Alexandre
Em 12/02/2014 19:44, "Nyall Dawson" <nyall.dawson at gmail.com> escreveu:
> On 13/02/2014 3:25 am, "Alexandre Neto" <senhor.neto at gmail.com> wrote:
> > Something similar happened to me the first time I tested.
> > I noticed that I needed to check the "controled by atlas" box in the map
> item properties tab (this was not necessary in 2.0.1). After that,
> everything worked fine.
> This is needed now because more than one map can be atlas controlled (or,
> potentially, no maps at all if you just want label items to change between
> features). I couldn't think of any better way of exposing this to the user.
> Ideas are welcome!
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140212/f610c34b/attachment.html>
