[Qgis-developer] Processing Toolbox in QGIS 2.0.1-Dufour does not show some toolboxes
    Victor Olaya
    volayaf at gmail.com
    Thu Feb 13 06:52:56 PST 2014
> I did not know that. Is the advanced interface the default one in the following
> versions? That would explain why I got the advanced toolbox when I compiled from
> the repo
No, the default one is the simplified. Maybe there is some issue with
the settings. Once you set the advanced, it should use it even if you
update, since it will take the parameter from the same setting. Maybe
there ha been some cahnge in the setting name and i do not remember
it...not sure
