[Qgis-developer] Processing Toolbox in QGIS 2.0.1-Dufour does not show some toolboxes
Roberto Antolin
rantolin.geo at gmail.com
Thu Feb 13 07:23:53 PST 2014
On Thu, Feb 13, 2014 at 03:52:56PM +0100, Victor Olaya wrote:
> > I did not know that. Is the advanced interface the default one in the following
> > versions? That would explain why I got the advanced toolbox when I compiled from
> > the repo
> No, the default one is the simplified. Maybe there is some issue with
> the settings. Once you set the advanced, it should use it even if you
> update, since it will take the parameter from the same setting. Maybe
> there ha been some cahnge in the setting name and i do not remember
> it...not sure
Ok, now I know what happened. I compiled the repo version some months ago and I
probably changed my set up to display the advanced interface.Then, I kept this
installation apart and completely isolated while I installed 2.0.1 version
yesterday. So, the repo version displays the advanced interface and the 2.0.1
version displays the simplified one.
Roberto
Roberto Antolín
https://twitter.com/Tolanss
