[Qgis-developer] Embedded group bug ?
Andreas Neumann
a.neumann at carto.net
Wed Feb 19 00:47:43 PST 2014
Hi Michael,
It is a known issue and Marco Hugentobler is working on it (hopefully
still in time for 2.2).
BTW: you will not be able to rearrange the order of individual layers if
you embed a whole group - only the group at a whole. But the order
within the embedded group should be correct once the bug is fixed. If
you want to reorder embedded groups or layers you will have to embed
them individually several times.
Andreas
Am 19.02.2014 08:41, schrieb kimaidou:
> Hi list,
> Yesterday I played a little bit with the feature "Embed layers or groups".
> I works well for single layers, but it seems to behave randomly for groups.
> For example, embedding a group containing sub-groups and layers does not
> produce the right result in my case : the group is imported, but only
> contains the sub-group. All the layers from parent project origninally
> contained in the group root are imported in the root of the legend in the
> child project. Second problem : the layers are imported with reverse order
> compared to their order in the parent project.
> Espected behaviour :
> * imported group
> -- * sub-group
> ---- * layer A
> ---- * layer B
> -- * layer 1
> -- * layer 2
> Actual "buggy" behaviour :
> * layer 2
> * layer 1
> * imported group
> -- * layer B
> -- * layer A
> And I cannot move the layers 1 and 2 afterwards in the "imported group" as
> the embedded groups are read-only.
> Has anyone seen this happen ?
> I would be happy to report a bug in hub.qgis.org
> Michael
> Qgis-developer mailing list
