[Qgis-developer] Embedded group bug ?
kimaidou kimaidou at gmail.com
Wed Feb 19 01:07:59 PST 2014
Another question regarding the embeded groups. Is there any way to tell if
a group is an embeded group with python bindings ? For layers, there is the
layerIsEmbeded method of the QgsProject class, but what about groups ?
Cheers
Michael
2014-02-19 9:57 GMT+01:00 kimaidou <kimaidou at gmail.com>:
> Thanks Adreas for your prompt answer.
> 2014-02-19 9:47 GMT+01:00 Andreas Neumann <a.neumann at carto.net>:
> Hi Michael,
>> It is a known issue and Marco Hugentobler is working on it (hopefully
>> still in time for 2.2).
> Ok. thanks Marco.
>> BTW: you will not be able to rearrange the order of individual layers if
>> you embed a whole group - only the group at a whole.
> Exactly. I just tried only because of the issue. I won't need it if groups
> and layers are embedded correctly.
>> But the order
>> within the embedded group should be correct once the bug is fixed. If
>> you want to reorder embedded groups or layers you will have to embed
>> them individually several times.
> This is what I did to avoid the bug after I discovered it. I recreated a
> group and sub groups with individual embeded layers in them. Then I use
> QGIS project templates to save this state and create new projects with the
> same group.
> Michael
>> Andreas
>> Am 19.02.2014 08:41, schrieb kimaidou:
>> > Hi list,
>> > Yesterday I played a little bit with the feature "Embed layers or
>> groups".
>> > I works well for single layers, but it seems to behave randomly for
>> groups.
>> > For example, embedding a group containing sub-groups and layers does not
>> > produce the right result in my case : the group is imported, but only
>> > contains the sub-group. All the layers from parent project origninally
>> > contained in the group root are imported in the root of the legend in
>> the
>> > child project. Second problem : the layers are imported with reverse
>> order
>> > compared to their order in the parent project.
>> > Espected behaviour :
>> > * imported group
>> > -- * sub-group
>> > ---- * layer A
>> > ---- * layer B
>> > -- * layer 1
>> > -- * layer 2
>> > Actual "buggy" behaviour :
>> > * layer 2
>> > * layer 1
>> > * imported group
>> > -- * layer B
>> > -- * layer A
>> > And I cannot move the layers 1 and 2 afterwards in the "imported group"
>> as
>> > the embedded groups are read-only.
>> > Has anyone seen this happen ?
>> > I would be happy to report a bug in hub.qgis.org
>> > Michael
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140219/c81475d1/attachment.html>
