[Qgis-developer] Embedded group bug ?
Andreas Neumann
a.neumann at carto.net
Wed Feb 19 01:31:10 PST 2014
I don't know. You will have to ask Marco.
Andreas
Am 19.02.2014 09:07, schrieb kimaidou:
> Hi,
> Another question regarding the embeded groups. Is there any way to tell if
> a group is an embeded group with python bindings ? For layers, there is the
> layerIsEmbeded method of the QgsProject class, but what about groups ?
> Cheers
> Michael
> 2014-02-19 9:57 GMT+01:00 kimaidou <kimaidou at gmail.com>:
>> Thanks Adreas for your prompt answer.
>> 2014-02-19 9:47 GMT+01:00 Andreas Neumann <a.neumann at carto.net>:
>> Hi Michael,
>>> It is a known issue and Marco Hugentobler is working on it (hopefully
>>> still in time for 2.2).
>> Ok. thanks Marco.
>>> BTW: you will not be able to rearrange the order of individual layers if
>>> you embed a whole group - only the group at a whole.
>> Exactly. I just tried only because of the issue. I won't need it if groups
>> and layers are embedded correctly.
>>> But the order
>>> within the embedded group should be correct once the bug is fixed. If
>>> you want to reorder embedded groups or layers you will have to embed
>>> them individually several times.
>> This is what I did to avoid the bug after I discovered it. I recreated a
>> group and sub groups with individual embeded layers in them. Then I use
>> QGIS project templates to save this state and create new projects with the
>> same group.
>> Michael
>>> Andreas
>>> Am 19.02.2014 08:41, schrieb kimaidou:
>>>> Hi list,
>>>> Yesterday I played a little bit with the feature "Embed layers or
>>> groups".
>>>> I works well for single layers, but it seems to behave randomly for
>>> groups.
>>>> For example, embedding a group containing sub-groups and layers does not
>>>> produce the right result in my case : the group is imported, but only
>>>> contains the sub-group. All the layers from parent project origninally
>>>> contained in the group root are imported in the root of the legend in
>>> the
>>>> child project. Second problem : the layers are imported with reverse
>>> order
>>>> compared to their order in the parent project.
>>>> Espected behaviour :
>>>> * imported group
>>>> -- * sub-group
>>>> ---- * layer A
>>>> ---- * layer B
>>>> -- * layer 1
>>>> -- * layer 2
>>>> Actual "buggy" behaviour :
>>>> * layer 2
>>>> * layer 1
>>>> * imported group
>>>> -- * layer B
>>>> -- * layer A
>>>> And I cannot move the layers 1 and 2 afterwards in the "imported group"
>>> as
>>>> the embedded groups are read-only.
>>>> Has anyone seen this happen ?
>>>> I would be happy to report a bug in hub.qgis.org
>>>> Michael
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
