[Qgis-developer] Failing tests consider blockers
Radim Blazek
radim.blazek at gmail.com
Wed Feb 19 06:52:53 PST 2014
On Wed, Feb 19, 2014 at 9:42 AM, Martin Dobias <wonder.sk at gmail.com> wrote:
> Also, renderer tests should IMHO have some tolerances instead a set of
> anomalies. For example, in multi-threading branch some tests started
> to fail because of some microscopic differences - this will require
> another set of reference images (and anomaly images) although there is
> no real difference. This looks like an interesting tool for comparing
> images:
> http://pdiff.sourceforge.net/
I have updated at least single symbol in rendererstest. I was not able
to get exactly the same image with the new renderer so I had to update
control image and remove all anomalies. I have added tolerance for
color components currently set to 15, i.e. about 6%, too much?
Radim
