[Qgis-developer] Which compiler for a c++ QGIS custom app
Rouzaud Denis
denis.rouzaud at gmail.com
Fri Feb 21 08:14:57 PST 2014
Hi Jürgen,
Thanks a lot for your reply.
It seems I should finally use Visual C++.
I will give it a try this weekend!
Thanks again and happy release ;)
Denis
On 21 Feb 2014, at 16:24, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Denis,
> On Fri, 21. Feb 2014 at 15:20:19 +0100, Denis Rouzaud wrote:
>> I have installed QGIS libs, Qt libs and minGW using osgeo4w installer
>> (thanks to Nathan's advices).
> mingw using the osgeo4w installer? That might be there for GRASS.
> But QGIS and Qt in OSGeo4W is built with Visual C++ not MinGW. You can't use
> OSGeo4W's Qt with MinGW.
>> Does someone know which compiler to use? Can't I use one embedded in
>> osgeo package?
>> PS: I don't have visual studio installed, and I would like to avoid
>> installing it.
> Sorry, I didn't do that for years - should also be possible, but I suppose it
> takes some work.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> QGIS PSC member (RM) Germany IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
