[Qgis-developer] Which compiler for a c++ QGIS custom app
Rouzaud Denis
denis.rouzaud at gmail.com
Mon Feb 24 03:10:53 PST 2014
Hi Jürgen,
On 21 Feb 2014, at 16:24, Jürgen E. Fischer <jef at norbit.de> wrote:
> But QGIS and Qt in OSGeo4W is built with Visual C++ not MinGW. You can't use
> OSGeo4W's Qt with MinGW.
I installed Visual Studio Express 2013, and it seems the compiler given with (version 12.0) is not compliant with Qt libs from the osgeo package.
Do you know if I should I restrict to a given version of the compiler? Which one has been used for building osgeo’s qt lib?
I saw that Nathan is using version 9.0.
Thanks a lot,
Denis
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140224/1d731dc9/attachment.html>
