[Qgis-developer] Which compiler for a c++ QGIS custom app
Nathan Woodrow madmanwoo at gmail.com
Mon Feb 24 03:14:00 PST 2014
The supported version is VS 2008.  I have never tried building with
anything else.
- Nathan
On Mon, Feb 24, 2014 at 9:10 PM, Rouzaud Denis <denis.rouzaud at gmail.com>wrote:
> Hi Jürgen,
> On 21 Feb 2014, at 16:24, Jürgen E. Fischer <jef at norbit.de> wrote:
> But QGIS and Qt in OSGeo4W is built with Visual C++ not MinGW.  You can't
> use
> OSGeo4W's Qt with MinGW.
> I installed Visual Studio Express 2013, and it seems the compiler given
> with (version 12.0) is not compliant with Qt libs from the osgeo package.
> Do you know if I should I restrict to a given version of the compiler?
> Which one has been used for building osgeo's qt lib?
> I saw that Nathan is using version 9.0.
> Thanks a lot,
> Denis
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140224/8af4bade/attachment.html>
