[Qgis-developer] Which compiler for a c++ QGIS custom app
    Rouzaud Denis
    denis.rouzaud at gmail.com
    Mon Feb 24 03:31:55 PST 2014
Thanks a lot  Nathan, this brought me further!
On 24 Feb 2014, at 12:14, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> The supported version is VS 2008.  I have never tried building with anything else.
> - Nathan
> On Mon, Feb 24, 2014 at 9:10 PM, Rouzaud Denis <denis.rouzaud at gmail.com> wrote:
> Hi Jürgen,
> On 21 Feb 2014, at 16:24, Jürgen E. Fischer <jef at norbit.de> wrote:
>> But QGIS and Qt in OSGeo4W is built with Visual C++ not MinGW.  You can't use
>> OSGeo4W's Qt with MinGW.
> I installed Visual Studio Express 2013, and it seems the compiler given with (version 12.0) is not compliant with Qt libs from the osgeo package.
> Do you know if I should I restrict to a given version of the compiler? Which one has been used for building osgeo’s qt lib?
> I saw that Nathan is using version 9.0.
> Thanks a lot,
> Denis
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140224/9521417d/attachment.html>
