[Qgis-developer] Post-release period of portable commits only?
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Mon Feb 24 07:05:37 PST 2014
Slightly deviating from the topic, but I'm quite fond of the GeoServer
release process; they're revamping a little to offer better Long Term
Support:
http://geoserver.org/display/GEOS/GSIP+107+-+Extended+Release+Schedule
I feel a similar system would solve most of QGIS' release problems:
- Bugfix releases
- LTS (if/when required)
- Predictable releases (though now fixed by QGIS)
- Clear test releases (betas and release candidates)
In comparison the QGIS release system feels... haphazard I guess is the
best word.
I know the common complaint is a lack of a resources, but QGIS has far more
resources than GeoServer - both in number of developers and the existence
of a "general fund".
Just thought I'd put it out there.
Cheers,
Jonathan
On 24 February 2014 14:41, Filipe Dias <filipesdias at gmail.com> wrote:
> How about making a formal announcement (mailing list, website, wiki etc)
> telling the users that QGIS version 2.X is in feature freeze and therefore
> is sufficiently stable to be tested by end users? This may increase the
> number of testers.
> As an end user that uses QGIS for production, this is the only time I work
> with QGIS Master.
> On Mon, Feb 24, 2014 at 2:17 PM, Jonathan Moules <
> jonathanmoules at warwickshire.gov.uk> wrote:
>>> Why not? We're talking about a feature freezed period!? The nightly
>>> build
>>> is a snapshot what what will get release. Where do you see a difference?
>> I think it's a perception thing.
>> "Nightly build" in my mind always means "bleeding edge may or may not
>> work, use at own risk." I'm aware that doesn't always mean "*it will
>> crash your computer, burn down your house, and spend your life savings on
>> questionable drugs*", but it's certainly not what I see as a synonym for
>> "stable" either.
>> Every time I see a nightly, it always comes with a big scary caveat (QGIS
>> does too - http://www.qgis.org/en/site/forusers/alldownloads.html ).
>> This trains users not to use them. Taking one of the nightlies and
>> re-branding it to something more amicable would get more folks to test it.
>> Just copy and paste it and rename the file. :-)
>> Cheers,
>> Jonathan
>>> > Very few average user will install a nightly development build, but
>>> you get
>>> > an higher chance of getting a broader number of people (that interacts
>>> with
>>> > QGIS in different ways) to test out your product before it's released.
>>> Why should it matter if we call it "weekly snapshot", "nightly build" or
>>> "prerelease"? It's the same thing, just the tag is different. And
>>> installation is essential as easy as installing the stable release.
>>> > It also helps channel what your describing as noise (i.e. users running
>>> > into problems) into a better managed call for people to test and
>>> report.
>>> > The noise will happen no matter what. But it might make some sense to
>>> > trigger some of that noise (valid bugs and "invalid" RTFM cases)
>>> _before_
>>> > you release your final version via a pre-release social media and news
>>> site
>>> > "try this pre-release build" :)
>>> > It's really more a matter of presentation to the users than of actual
>>> work.
>>> Exactly. And that's what I meant with noise: "tada, there's a new weekly
>>> snapshot/prerelease/nightly build" - not users running into problems.
>>> Because
>>> I see that as the only significant difference to what we already have.
>>> Jürgen
>>> Jürgen E. Fischer norBIT GmbH Tel.
>>> +49-4931-918175-31
>>> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>>> +49-4931-918175-50
>>> Software Engineer D-26506 Norden
>>> http://www.norbit.de
>>> QGIS PSC member (RM) Germany IRC: jef on
>>> FreeNode
>>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>>> Rheinstrasse 13, 26506 Norden
>>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> This transmission is intended for the named addressee(s) only and may
>> contain sensitive or protectively marked material up to RESTRICTED and
>> should be handled accordingly. Unless you are the named addressee (or
>> authorised to receive it for the addressee) you may not copy or use it, or
>> disclose it to anyone else. If you have received this transmission in error
>> please notify the sender immediately. All email traffic sent to or from us,
>> including without limitation all GCSX traffic, may be subject to recording
>> and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140224/840953f9/attachment.html>
