[Qgis-developer] Rendering feature symbol when feature is not visible
Jordi Torres
jtorresfabra at gmail.com
Tue Feb 25 02:50:28 PST 2014
Solved it myself. Finally I inherited from the QgsXXXRendererV2 and
overrided the startRender() method in order to modify the renderContext to
meet my project needs. This is not a perfect solution, but it works for me
as the layers I want to render are quite small and it does not become in an
overhead.
Thanks anyway.
Cheers.
2014-02-24 15:35 GMT+01:00 Jordi Torres <jtorresfabra at gmail.com>:
> Hi all,
> I'm trying to render marker symbols that are bigger than the feature
> geometry bounding box. When the feature is not visible (because it is out
> of the current extent) the symbol isn't rendered.
> I think the code in the draw method of qgsvectorlayer.cpp is:
> QgsFeatureIterator fit = getFeatures( QgsFeatureRequest()
> .setFilterRect( rendererContext.extent() )
> .setSubsetOfAttributes( attributes ) );
> Ok, this is a expected behaviour, but is there anyway (using C++ API) to
> change this behaviour without extending QgsVectorLayer? I suppose that if
> I could pass the renderContext with the whole layer extent it would do the
> trick.
> Any suggestions or ideas?
> Thanks in advance.
> Jordi Torres
Jordi Torres
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140225/6f8b04a3/attachment.html>
