[Qgis-developer] Some notes of 2.2. OpenSuse 12.3 ""release"
Kari Salovaara
kari.salovaara at pp1.inet.fi
Tue Feb 25 06:22:09 PST 2014
Replied privately (due files not for public)
Cheers,
Kari
On 02/25/2014 02:50 PM, Angelos Tzotsos wrote:
> Hi,
> On 02/25/2014 05:04 AM, Kari Salovaara wrote:
>> Hi,
>> thanks for all developers of huge and fantastic work again.
>> I've OpenSuse 12.3 updated about per midnight (GMT 24.2.2014 23:00). and
>> qgis2-2.2.0-6.1
> Can you please provide a full list of repositories that you have
> enabled in your 12.3 environment?
>> I'd some notices of small "bugs". I was not able to use other
>> machinery so I
>> don't know ......
>> 1. Manage and Install Plugins ... -> Upgradeable ; I've two left after I
>> upgraded all others.
>> mmqgis and Qgis2threejs both tell "There is a new version available"
>> I've tried both Upgrade all and Upgrade plugin. Restarted QGIS and
>> tried again.
>> They just won't want to be upgraded.
> Please try to erase those plugins completely from your environment and
> install again from the Plugins Manager.
> I cannot reproduce this issue.
>> Then I uninstalled mmqgis and installed again. Now it has been
>> upgraded but is
>> again in the list of upgradeable. If You look the numbering where I
>> expect the
>> error lie ?
>> Installed version: 2014.01.06 (in
>> /home/kari/.qgis2/python/plugins/mmqgis)
>> Available version: 2014.1.6 (in QGIS Official Plugin Repository)
>> - and uninstall->install>result was also
>> Installed version: 0.06 (in
>> /home/kari/.qgis2/python/plugins/Qgis2threejs)
>> Available version: 0.6 (in QGIS Official Plugin Repository)
>> - those leading zeroes ?
> Please try to wipe out .qgis2 folder and re-install the plugins.
>> 2. jp2 (Jpeg2000) files don't work/render at all. That was not a
>> surprise in
>> OpenSuse. Have to force kill and restart qgis.
> It is a surprise to me, openSUSE was the first distribution to have
> OpenJPEG v2 packaged in Factory...
> Plus, I can work with jp2 files in 13.1
> Can you please provide a jp2 file that fails for you so I can test?
>> 3. in About -> License is missing (totally white) ;)
> Confirmed, I will take a look at this, thanks.
>> Regards,
>> Kari
>> PS. Installation
>> QGIS version 2.2.0-Valmiera QGIS code revision exported
>> Compiled against Qt 4.8.4 Running against Qt 4.8.4
>> Compiled against GDAL/OGR 1.10.1 Running against GDAL/OGR 1.10.1
>> Compiled against GEOS 3.4.2-CAPI-1.8.2 Running against GEOS
>> 3.4.2-CAPI-1.8.2 r3921
>> PostgreSQL Client Version 9.2.4 SpatiaLite Version 4.1.1
>> QWT Version 5.2.3 PROJ.4 Version 480
>> QScintilla2 Version
>> Kari Salovaara
>> Hanko, Finland
>> "Volunteers do not necessarily have the time; they just have the
>> heart." ~Elizabeth Andrew
> Thank you for your feedback.
> Best,
> Angelos
Kari Salovaara
Hanko, Finland
"Volunteers do not necessarily have the time; they just have the heart." ~Elizabeth Andrew
