[Qgis-developer] QGIS Server SLD GetStyles method bug?
Alessandro Pasotti
apasotti at gmail.com
Mon Jan 6 02:37:29 PST 2014
2014/1/6 Marco Hugentobler <marco.hugentobler at sourcepole.ch>
> Hi
> QGIS server has its own GetStyle method because implementation of the
> server started based on WMS 1.3/SLD1.1. It seems OGC GetStyles is only
> present in WMS1.1.1/SLD1.0 and has been dropped afterwards. So it seems to
> me the bug in the server code is that GetStyles is directed to QGIS
> GetStyle.
> I'm aware that WMS 1.1.1/SLD1.0 are very frequently used. So a patch to
> add OGC GetStyles behaviour for 1.1.1 is very welcome.
Hi Marco,
thank you for clarifying, you are absolutely right and it seems that it was
dropped after 1.0, my issue is related to "GetStyles" request, (please
notice the trailing "s"), I used this documentation
(02-070_Styled_Layer_Descriptor_Implementation_Specification.pdf,
http://portal.opengeospatial.org/files/?artifact_id=1188) :
13.1. GetStyles
The GetStyles operation is used to retrieve user-defined styles from a WMS.
The
parameters of the HTTP-GET method are defined as follows:
Parameter Required Description VERSION Required
Version as required by OGC interfaces.
REQUEST Required Value must be “GetStyles”.
LAYERS Required Comma-separated list of named layers for which to retrieve
style
descriptions.
SLDVER Optional The SLD version requested for the SLD document. The default
is
to return the highest version supported by the server. If a version
is requested that the server does not support, then the next lower
supported version is supported by the server is returned, or the
server’s lowest supported version. This is similar to WMS version
negotiation.
If I understand this correctly, we should split GetStyle and GetStyles
calls and support the second one only if SLDVER is set and SLDVER=1.0.0,
raise an exception if not match.
GetStyles should then accept the following parameters:
REQUEST=GetStyles
LAYERS=comma separated list of TypeNames
SLDVER=1.0.0 (this seems the only version that supports GetStyles)
BTW: does anybody know what method took the place of GetStyles after it was
dropped?
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140106/b804d88c/attachment.html>
