[Qgis-developer] attribute table issues
Matthias Kuhn
matthias.kuhn at gmx.ch
Mon Jan 13 04:04:30 PST 2014
On 01/13/2014 11:46 AM, Alessandro Pasotti wrote:
> 2014/1/13 Régis Haubourg <regis.haubourg at eau-adour-garonne.fr
> <mailto:regis.haubourg at eau-adour-garonne.fr>>
> Hi there,
> as feature freeze is coming, I raise an issue i didn't find in the
> lists or
> in the tracker.
> When working with attribute table, I had many problems on a
> classical use
> case. I just explore attribute table, filter, order, and then
> select lines,
> and zoom on the map.
> - selection of lines is very slow even for small tables. Do we need to
> trigger redraws when the selected features are not in current canvas?
> Anyway, selecting/ unselecting is to slow
> - selected line(s) are grey, and my eyes can't see a difference
> with other
> non selected lines. I liked old blue 1.x color.
> - When selecting a set of feature (using maps tools or
> expression), my first
> idea is to explore the selected fetaures one by one. So I click on
> one and
> then will zoom on the feature, but this refreshes current
> selection. When
> displaying only selected items, I loose then my set of selected
> objects.
> What is the right workflow? Is there a way to convert a manual
> selection set
> into a filter? Or could we add a contextual click to 'zoom on the
> feature',
> not modifying current selection?
> Tell me if I need to open tickets or if someone is already on it.
> Cheers,
> Régis
> I'd just add to your notes that IMHO the current attribute search is
> much less usable than the old one, I feel that the most frequent
> operation is filtering but you have now to dig into the combo and
> choose "column filter" to actvate one, while in previous versions the
> filtering functions were immediately available.
What would be the solution to this?
Promoting the columns to top-level items instead of second-level items?
Or having a single toplevel "Search" item, which searches on all columns?
> Alessandro Pasotti
> w3: www.itopen.it <http://www.itopen.it>
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140113/e4e2094a/attachment.html>
