[Qgis-developer] forced update on the repo?
Matthias Kuhn matthias.kuhn at gmx.ch
Mon Jan 13 04:47:49 PST 2014
Thank you Tim,
Small change:
"Don't merge anything in other than master"
I would remove "other than master".
Instead of merging in master, one should rather rebase on top of master
like explained in the lines below. This keeps the history cleaner.
Regards,
Matthias
On Mon 13 Jan 2014 01:39:03 PM CET, Tim Sutton wrote:
> Hi
> On Mon, Jan 13, 2014 at 1:59 PM, Tim Sutton <lists at linfiniti.com
> <mailto:lists at linfiniti.com>> wrote:
>     Hi
>     On Mon, Jan 13, 2014 at 11:35 AM, Richard Duivenvoorde
>     <rdmailings at duif.net <mailto:rdmailings at duif.net>> wrote:
>         On 13-01-14 10:18, Matthias Kuhn wrote:
>         > Some general advice (althogh I'm not sure how exactly that
>         happened) is to
>         > For creating a pull request
>         > - always start a feature branch from current master
>         > - if you are coding a feature branch, don't "merge" anything in
>         > - before you create a pull request do "git fetch origin" and
>         "git rebase
>         > origin/master" (given origin is the remote for upstream and
>         not your own
>         > remote, check your .git/config or do "git remote -v | grep
>         > github.com/qgis <http://github.com/qgis>")
>         > - you may do a "git rebase" like in the last line repeatedly
>         without
>         > doing any damage (as long as the only purpose of your branch
>         is to get
>         > merged into master)
>         > - Attention: After a rebase you need to "git push -f". CORE
>         DEVS: IF YOU
>         > DO THIS ON THE UPSTREAM REPOSITORY YOU WILL BRING CAKE FOR
>         EVERYBODY TO
>         > THE NEXT HF!
>         > For merging a pull request
>         > Option A)
>         >   - click the merge button (Creates a non-fast-forward merge)
>         > Option B)
>         >   - Checkout the pull request (See
>         > https://gist.github.com/piscisaureus/3342247)
>         >   - Test (Also required for option A, obviously)
>         >   - checkout master, "git merge pr/1234"
>         >   - Optional: "git pull --rebase": Creates a fast-forward,
>         no "merge
>         > commit" is made. Cleaner history, but it is harder to revert
>         the merge.
>         >   - "git push"
>         > I hope that I got things right and that somebody finds this
>         useful.
>         Hi Matthias,
>         I think it is VERY usefull. But I also think we should create a
>         'git'-page in documentation which contains this info.
>         I think it would also be helpfull to show the (more general) git
>         commands for creating a local branch etc.
>         I'll try to create a page for that with the information above,
>         and add
>         some stuff that I think is usefull.
>         Plz have a look into it when finished.
>     Richard this kind of stuff should go in the CODING doc. I have
>     already added some infor on Pull Requests there  following our
>     previous to last PSC meeting, and just updated it with Matthias'
>     notes too. I'm just waiting for my internet to allow me to
>     actually push it.....
> Commit is here:
> https://github.com/qgis/QGIS/commit/e745b2ffa5a6f1a249dedba18eded232857097c7
> Regards
> Tim
>     Regards
>     Tim
>         Regards,
>         _______________________________________________
>         Qgis-developer mailing list
>         Qgis-developer at lists.osgeo.org
>         <mailto:Qgis-developer at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Tim Sutton - QGIS Project Steering Committee Member
>     Please do not email me off-list with technical
>     support questions. Using the lists will gain
>     more exposure for your issues and the knowledge
>     surrounding your issue will be shared with all.
>     Irc: timlinux on #qgis at freenode.net <http://freenode.net>
