[Qgis-developer] forced update on the repo?
Tim Sutton
lists at linfiniti.com
Mon Jan 13 05:02:07 PST 2014
Hi
On Mon, Jan 13, 2014 at 2:47 PM, Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
> Thank you Tim,
> Small change:
> "Don't merge anything in other than master"
> I would remove "other than master".
> Instead of merging in master, one should rather rebase on top of master
> like explained in the lines below. This keeps the history cleaner.
Done with a273b69 thanks.
T
> Regards,
> Matthias
> On Mon 13 Jan 2014 01:39:03 PM CET, Tim Sutton wrote:
>> Hi
>> On Mon, Jan 13, 2014 at 1:59 PM, Tim Sutton <lists at linfiniti.com
>> <mailto:lists at linfiniti.com>> wrote:
>> Hi
>> On Mon, Jan 13, 2014 at 11:35 AM, Richard Duivenvoorde
>> <rdmailings at duif.net <mailto:rdmailings at duif.net>> wrote:
>> On 13-01-14 10:18, Matthias Kuhn wrote:
>> > Some general advice (althogh I'm not sure how exactly that
>> happened) is to
>> > For creating a pull request
>> > - always start a feature branch from current master
>> > - if you are coding a feature branch, don't "merge" anything in
>> > - before you create a pull request do "git fetch origin" and
>> "git rebase
>> > origin/master" (given origin is the remote for upstream and
>> not your own
>> > remote, check your .git/config or do "git remote -v | grep
>> > github.com/qgis <http://github.com/qgis>")
>> > - you may do a "git rebase" like in the last line repeatedly
>> without
>> > doing any damage (as long as the only purpose of your branch
>> is to get
>> > merged into master)
>> > - Attention: After a rebase you need to "git push -f". CORE
>> DEVS: IF YOU
>> > DO THIS ON THE UPSTREAM REPOSITORY YOU WILL BRING CAKE FOR
>> EVERYBODY TO
>> > THE NEXT HF!
>> > For merging a pull request
>> > Option A)
>> > - click the merge button (Creates a non-fast-forward merge)
>> > Option B)
>> > - Checkout the pull request (See
>> > https://gist.github.com/piscisaureus/3342247)
>> > - Test (Also required for option A, obviously)
>> > - checkout master, "git merge pr/1234"
>> > - Optional: "git pull --rebase": Creates a fast-forward,
>> no "merge
>> > commit" is made. Cleaner history, but it is harder to revert
>> the merge.
>> > - "git push"
>> > I hope that I got things right and that somebody finds this
>> useful.
>> Hi Matthias,
>> I think it is VERY usefull. But I also think we should create a
>> 'git'-page in documentation which contains this info.
>> I think it would also be helpfull to show the (more general) git
>> commands for creating a local branch etc.
>> I'll try to create a page for that with the information above,
>> and add
>> some stuff that I think is usefull.
>> Plz have a look into it when finished.
>> Richard this kind of stuff should go in the CODING doc. I have
>> already added some infor on Pull Requests there following our
>> previous to last PSC meeting, and just updated it with Matthias'
>> notes too. I'm just waiting for my internet to allow me to
>> actually push it.....
>> Commit is here:
>> https://github.com/qgis/QGIS/commit/e745b2ffa5a6f1a249dedba18eded2
>> 32857097c7
>> Regards
>> Tim
>> Regards
>> Tim
>> Regards,
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> <mailto:Qgis-developer at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Tim Sutton - QGIS Project Steering Committee Member
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Irc: timlinux on #qgis at freenode.net <http://freenode.net>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140113/15b18527/attachment-0001.html>
