[Qgis-developer] Qgis web client search
Mira Maric mmmxxxm at gmail.com
Thu Jan 16 03:09:43 PST 2014
I set up Apache config file:
insert following lines:
- LoadModule wsgi_module modules/mod_wsgi.so
and
 WSGIScriptAlias /wsgi C:\OSGeo4W\apache\htdocs\qgis-web-client-master\wsgi
 WSGIScriptAliasMatch ^/wsgi/([^/]+)
"C:\OSGeo4W\apache\htdocs\qgis-web-client-master\$1.wsgi"
, after this I create tables in Posgis and modify connection string in
search.wsgi and getSearchGeom.wsgi.
Now when I run web page and try to search in search box I get this error:
Resource interpreted as Script but transferred with MIME type text/plain:
 "http://localhost:89/qgis-web-client-master/wsgi/search.wsgi?query=&searchtables=&query=89&cb=stcCallback1001".
ext-all.js:7
Uncaught SyntaxError: Unexpected token ILLEGAL search.wsgi:1
2014/1/16 Bernhard Ströbl <bernhard.stroebl at jena.de>:
> Hi,
> I have no idea, where this is located on Windows...
> but you need to adapt the wsgi files you downloaded from github with QWC to
> your db settings (see section 6.2)!
> Bernhard
> P.S. please try to reply to the list
> Am 16.01.2014 10:17, schrieb Mira Maric:
>> Hi!
>> I do the following:
>> I download mod_wsgi.so from
>> http://www.lfd.uci.edu/~gohlke/pythonlibs/#mod_wsgi an put it in:
>> C:\OSGeo4W\apache\modules
>>   In Apache config file I added line:
>>      -LoadModule wsgi_module modules/mod_wsgi.so
>> I restart apache and turn it on, it's work OK. Now I don't know  where
>> to do this, where is file for this settings?
>> I am using Windows!
>>    6.1. Configuration of mod_wsgi
>> You need to enable mod_wsgi as root. (Ubuntu: a2enmod mod_wsgi).
>> You need to configure apache with the following lines (e.g. in file
>> /etc/apache2/sites-available/default):
>>    #mod_wsgi
>>    WSGIDaemonProcess gis processes=5 threads=15 display-name=%{GROUP}
>>    WSGIScriptAlias /wsgi/ /home/www/wsgi/
>>    WSGIScriptAliasMatch ^/wsgi/([^/]+) /home/www/wsgi/$1.wsgi
>> Thanks!
>> 2014/1/16 Mira Maric<mmmxxxm at gmail.com>:
>>> Hi!
>>> I do the following:
>>> to do this
>>> Uncaught SyntaxError: Unexpected token ILLEGAL in search.wsgi:1
>>> 2014/1/16 Bernhard Ströbl<bernhard.stroebl at jena.de>:
>>>> Hi,
>>>> did you configure the wsgi scripts to match your database and did you
>>>> provide the search tables in the database?
>>>> Both is described in the README (section 6) [1]
>>>> Bernhard
>>>> [1] https://github.com/qgis/QGIS-Web-Client
>>>> Am 16.01.2014 07:33, schrieb Mira Maric:
>>>>>   1.
>>>>>      First I added line in Apache config file:
>>>>>   2.
>>>>>      In GlobalOption.js I set var useGeoNamesSearchBox = false; var
>>>>>      searchBoxQueryURL
>>>>> ="http://localhost:89/qgis-web-client-master/wsgi/search.wsgi?query=";
>>>>>      var searchBoxGetGeomURL
>>>>> ="http://localhost:89/qgis-web-client-master/wsgi/getSearchGeom.wsgi";
>>>>> When i try to search, i do not get anything! Is there any example for
>>>>> searching setup?
> __________ Information from ESET Mail Security, version of virus signature
> database 9296 (20140115) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
