[Qgis-developer] Qgis web client search
Bernhard Ströbl
bernhard.stroebl at jena.de
Thu Jan 16 01:50:39 PST 2014
I have no idea, where this is located on Windows...
but you need to adapt the wsgi files you downloaded from github with QWC
to your db settings (see section 6.2)!
Bernhard
P.S. please try to reply to the list
Am 16.01.2014 10:17, schrieb Mira Maric:
> Hi!
> I do the following:
> I download mod_wsgi.so from
> http://www.lfd.uci.edu/~gohlke/pythonlibs/#mod_wsgi an put it in:
> C:\OSGeo4W\apache\modules
> In Apache config file I added line:
> -LoadModule wsgi_module modules/mod_wsgi.so
> I restart apache and turn it on, it's work OK. Now I don't know where
> to do this, where is file for this settings?
> I am using Windows!
> 6.1. Configuration of mod_wsgi
> You need to enable mod_wsgi as root. (Ubuntu: a2enmod mod_wsgi).
> You need to configure apache with the following lines (e.g. in file
> /etc/apache2/sites-available/default):
> #mod_wsgi
> WSGIDaemonProcess gis processes=5 threads=15 display-name=%{GROUP}
> WSGIScriptAlias /wsgi/ /home/www/wsgi/
> WSGIScriptAliasMatch ^/wsgi/([^/]+) /home/www/wsgi/$1.wsgi
> Thanks!
> 2014/1/16 Mira Maric<mmmxxxm at gmail.com>:
>> Hi!
>> I do the following:
>> to do this
>> Uncaught SyntaxError: Unexpected token ILLEGAL in search.wsgi:1
>> 2014/1/16 Bernhard Ströbl<bernhard.stroebl at jena.de>:
>>> Hi,
>>> did you configure the wsgi scripts to match your database and did you
>>> provide the search tables in the database?
>>> Both is described in the README (section 6) [1]
>>> Bernhard
>>> [1] https://github.com/qgis/QGIS-Web-Client
>>> Am 16.01.2014 07:33, schrieb Mira Maric:
>>>> 1.
>>>> First I added line in Apache config file:
>>>> 2.
>>>> In GlobalOption.js I set var useGeoNamesSearchBox = false; var
>>>> searchBoxQueryURL
>>>> ="http://localhost:89/qgis-web-client-master/wsgi/search.wsgi?query=";
>>>> var searchBoxGetGeomURL
>>>> ="http://localhost:89/qgis-web-client-master/wsgi/getSearchGeom.wsgi";
>>>> When i try to search, i do not get anything! Is there any example for
>>>> searching setup?
__________ Information from ESET Mail Security, version of virus signature database 9296 (20140115) __________
The message was checked by ESET Mail Security.
http://www.eset.com
