[Qgis-developer] Qgis web client search
Mira Maric mmmxxxm at gmail.com
Thu Jan 16 03:27:19 PST 2014
When I enter URL in browser:
http://localhost:89/qgis-web-client-master/wsgi/search.wsgi?query=&searchtables=&query=pl&cb=stcCallback1002
I get the content of search.wsgi file!
This is my log of access file:
127.0.0.1 - - [16/Jan/2014:11:50:26 +0100] "GET
/qgis-web-client-master/wsgi/search.wsgi?query=&searchtables=&query=89&cb=stcCallback1001
HTTP/1.1" 200 5723
127.0.0.1 - - [16/Jan/2014:12:08:29 +0100] "GET
HTTP/1.1" 200 5723
This is my log of error file:
[Thu Jan 16 11:50:49 2014] [notice] Parent: Received restart signal --
Restarting the server.
[Thu Jan 16 11:50:49 2014] [notice] Child 8856: Exit event signaled.
Child process is ending.
[Thu Jan 16 11:50:49 2014] [warn] mod_wsgi: Compiled for Python/3.3.0.
[Thu Jan 16 11:50:49 2014] [warn] mod_wsgi: Runtime using Python/3.3.2.
[Thu Jan 16 11:50:49 2014] [notice] Apache/2.2.14 (Win32)
mod_wsgi/3.5-BRANCH Python/3.3.2 mod_fcgid/2.3.6 configured --
resuming normal operations
[Thu Jan 16 11:50:49 2014] [notice] Server built: Sep 28 2009 22:41:08
[Thu Jan 16 11:50:49 2014] [notice] Parent: Created child process 6020
[Thu Jan 16 11:50:49 2014] [notice] Child 6020: Child process is running
[Thu Jan 16 11:50:50 2014] [notice] Child 6020: Acquired the start mutex.
[Thu Jan 16 11:50:50 2014] [notice] Child 8856: Released the start mutex
[Thu Jan 16 11:50:50 2014] [notice] Child 6020: Starting 64 worker threads.
[Thu Jan 16 11:50:50 2014] [notice] Child 6020: Starting thread to
listen on port 89.
[Thu Jan 16 11:50:51 2014] [notice] Child 8856: All worker threads have exited.
[Thu Jan 16 11:50:51 2014] [notice] Child 8856: Child process is exiting
2014/1/16 Bernhard Ströbl <bernhard.stroebl at jena.de>:
> Hi,
> try to enter the url of the wsgi-script directly in your browser and see
> what it returns, check QWC's log file for any errors of the wsgi script.
> Bernhard
> Am 16.01.2014 12:09, schrieb Mira Maric:
>> I set up Apache config file:
>> insert following lines:
>> - LoadModule wsgi_module modules/mod_wsgi.so
>> and
>>   WSGIScriptAlias /wsgi
>> C:\OSGeo4W\apache\htdocs\qgis-web-client-master\wsgi
>>   WSGIScriptAliasMatch ^/wsgi/([^/]+)
>> "C:\OSGeo4W\apache\htdocs\qgis-web-client-master\$1.wsgi"
>> , after this I create tables in Posgis and modify connection string in
>> search.wsgi and getSearchGeom.wsgi.
>> Now when I run web page and try to search in search box I get this error:
>> Resource interpreted as Script but transferred with MIME type text/plain:
>> "http://localhost:89/qgis-web-client-master/wsgi/search.wsgi?query=&searchtables=&query=89&cb=stcCallback1001".
>> ext-all.js:7
>> Uncaught SyntaxError: Unexpected token ILLEGAL search.wsgi:1
>> 2014/1/16 Bernhard Ströbl<bernhard.stroebl at jena.de>:
>>> Hi,
>>> I have no idea, where this is located on Windows...
>>> but you need to adapt the wsgi files you downloaded from github with QWC
>>> to
>>> your db settings (see section 6.2)!
>>> Bernhard
>>> P.S. please try to reply to the list
>>> Am 16.01.2014 10:17, schrieb Mira Maric:
>>>> Hi!
>>>> I do the following:
>>>> I download mod_wsgi.so from
>>>> http://www.lfd.uci.edu/~gohlke/pythonlibs/#mod_wsgi an put it in:
>>>> C:\OSGeo4W\apache\modules
>>>>    In Apache config file I added line:
>>>>       -LoadModule wsgi_module modules/mod_wsgi.so
>>>> I restart apache and turn it on, it's work OK. Now I don't know  where
>>>> to do this, where is file for this settings?
>>>> I am using Windows!
>>>>     6.1. Configuration of mod_wsgi
>>>> You need to enable mod_wsgi as root. (Ubuntu: a2enmod mod_wsgi).
>>>> You need to configure apache with the following lines (e.g. in file
>>>> /etc/apache2/sites-available/default):
>>>>     #mod_wsgi
>>>>     WSGIDaemonProcess gis processes=5 threads=15 display-name=%{GROUP}
>>>>     WSGIScriptAlias /wsgi/ /home/www/wsgi/
>>>>     WSGIScriptAliasMatch ^/wsgi/([^/]+) /home/www/wsgi/$1.wsgi
>>>> Thanks!
>>>> 2014/1/16 Mira Maric<mmmxxxm at gmail.com>:
>>>>> Hi!
>>>>> I do the following:
>>>>> to do this
>>>>> Uncaught SyntaxError: Unexpected token ILLEGAL in search.wsgi:1
>>>>>> Hi,
>>>>>> did you configure the wsgi scripts to match your database and did you
>>>>>> provide the search tables in the database?
>>>>>> Both is described in the README (section 6) [1]
>>>>>> Bernhard
>>>>>> [1] https://github.com/qgis/QGIS-Web-Client
>>>>>> Am 16.01.2014 07:33, schrieb Mira Maric:
>>>>>>>    1.
>>>>>>>       First I added line in Apache config file:
>>>>>>>    2.
>>>>>>>       In GlobalOption.js I set var useGeoNamesSearchBox = false; var
>>>>>>>       searchBoxQueryURL
>>>>>>> ="http://localhost:89/qgis-web-client-master/wsgi/search.wsgi?query=";
>>>>>>>       var searchBoxGetGeomURL
>>>>>>> ="http://localhost:89/qgis-web-client-master/wsgi/getSearchGeom.wsgi";
>>>>>>> When i try to search, i do not get anything! Is there any example for
>>>>>>> searching setup?
> __________ Information from ESET Mail Security, version of virus signature
> database 9297 (20140116) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
