[Qgis-developer] Qgis web client search
Bernhard Ströbl
bernhard.stroebl at jena.de
Thu Jan 16 03:43:25 PST 2014
I wonder why the query parameter is included twice but on my server
(Linux, though) it does not matter...
Anyhow I _think_ the script is not executed but I cannot help here.
Maybe you want to search the web for "wsgi" and "Windows"
Bernhard
Am 16.01.2014 12:27, schrieb Mira Maric:
> When I enter URL in browser:
> http://localhost:89/qgis-web-client-master/wsgi/search.wsgi?query=&searchtables=&query=pl&cb=stcCallback1002
> I get the content of search.wsgi file!
> This is my log of access file:
> 127.0.0.1 - - [16/Jan/2014:11:50:26 +0100] "GET
> /qgis-web-client-master/wsgi/search.wsgi?query=&searchtables=&query=89&cb=stcCallback1001
> HTTP/1.1" 200 5723
> 127.0.0.1 - - [16/Jan/2014:12:08:29 +0100] "GET
> HTTP/1.1" 200 5723
> This is my log of error file:
> [Thu Jan 16 11:50:49 2014] [notice] Parent: Received restart signal --
> Restarting the server.
> [Thu Jan 16 11:50:49 2014] [notice] Child 8856: Exit event signaled.
> Child process is ending.
> [Thu Jan 16 11:50:49 2014] [warn] mod_wsgi: Compiled for Python/3.3.0.
> [Thu Jan 16 11:50:49 2014] [warn] mod_wsgi: Runtime using Python/3.3.2.
> [Thu Jan 16 11:50:49 2014] [notice] Apache/2.2.14 (Win32)
> mod_wsgi/3.5-BRANCH Python/3.3.2 mod_fcgid/2.3.6 configured --
> resuming normal operations
> [Thu Jan 16 11:50:49 2014] [notice] Server built: Sep 28 2009 22:41:08
> [Thu Jan 16 11:50:49 2014] [notice] Parent: Created child process 6020
> [Thu Jan 16 11:50:49 2014] [notice] Child 6020: Child process is running
> [Thu Jan 16 11:50:50 2014] [notice] Child 6020: Acquired the start mutex.
> [Thu Jan 16 11:50:50 2014] [notice] Child 8856: Released the start mutex
> [Thu Jan 16 11:50:50 2014] [notice] Child 6020: Starting 64 worker threads.
> [Thu Jan 16 11:50:50 2014] [notice] Child 6020: Starting thread to
> listen on port 89.
> [Thu Jan 16 11:50:51 2014] [notice] Child 8856: All worker threads have exited.
> [Thu Jan 16 11:50:51 2014] [notice] Child 8856: Child process is exiting
> 2014/1/16 Bernhard Ströbl<bernhard.stroebl at jena.de>:
>> Hi,
>> try to enter the url of the wsgi-script directly in your browser and see
>> what it returns, check QWC's log file for any errors of the wsgi script.
>> Bernhard
>> Am 16.01.2014 12:09, schrieb Mira Maric:
>>> I set up Apache config file:
>>> insert following lines:
>>> - LoadModule wsgi_module modules/mod_wsgi.so
>>> and
>>> WSGIScriptAlias /wsgi
>>> C:\OSGeo4W\apache\htdocs\qgis-web-client-master\wsgi
>>> WSGIScriptAliasMatch ^/wsgi/([^/]+)
>>> "C:\OSGeo4W\apache\htdocs\qgis-web-client-master\$1.wsgi"
>>> , after this I create tables in Posgis and modify connection string in
>>> search.wsgi and getSearchGeom.wsgi.
>>> Now when I run web page and try to search in search box I get this error:
>>> Resource interpreted as Script but transferred with MIME type text/plain:
>>> "http://localhost:89/qgis-web-client-master/wsgi/search.wsgi?query=&searchtables=&query=89&cb=stcCallback1001".
>>> ext-all.js:7
>>> Uncaught SyntaxError: Unexpected token ILLEGAL search.wsgi:1
>>>> Hi,
>>>> I have no idea, where this is located on Windows...
>>>> but you need to adapt the wsgi files you downloaded from github with QWC
>>>> to
>>>> your db settings (see section 6.2)!
>>>> Bernhard
>>>> P.S. please try to reply to the list
>>>> Am 16.01.2014 10:17, schrieb Mira Maric:
>>>>> Hi!
>>>>> I do the following:
>>>>> I download mod_wsgi.so from
>>>>> http://www.lfd.uci.edu/~gohlke/pythonlibs/#mod_wsgi an put it in:
>>>>> C:\OSGeo4W\apache\modules
>>>>> In Apache config file I added line:
>>>>> -LoadModule wsgi_module modules/mod_wsgi.so
>>>>> I restart apache and turn it on, it's work OK. Now I don't know where
>>>>> to do this, where is file for this settings?
>>>>> I am using Windows!
>>>>> 6.1. Configuration of mod_wsgi
>>>>> You need to enable mod_wsgi as root. (Ubuntu: a2enmod mod_wsgi).
>>>>> You need to configure apache with the following lines (e.g. in file
>>>>> /etc/apache2/sites-available/default):
>>>>> #mod_wsgi
>>>>> WSGIDaemonProcess gis processes=5 threads=15 display-name=%{GROUP}
>>>>> WSGIScriptAlias /wsgi/ /home/www/wsgi/
>>>>> WSGIScriptAliasMatch ^/wsgi/([^/]+) /home/www/wsgi/$1.wsgi
>>>>> Thanks!
>>>>> 2014/1/16 Mira Maric<mmmxxxm at gmail.com>:
>>>>>> Hi!
>>>>>> I do the following:
>>>>>> to do this
>>>>>> Uncaught SyntaxError: Unexpected token ILLEGAL in search.wsgi:1
>>>>>>> Hi,
>>>>>>> did you configure the wsgi scripts to match your database and did you
>>>>>>> provide the search tables in the database?
>>>>>>> Both is described in the README (section 6) [1]
>>>>>>> Bernhard
>>>>>>> [1] https://github.com/qgis/QGIS-Web-Client
>>>>>>> Am 16.01.2014 07:33, schrieb Mira Maric:
>>>>>>>> 1.
>>>>>>>> First I added line in Apache config file:
>>>>>>>> 2.
>>>>>>>> In GlobalOption.js I set var useGeoNamesSearchBox = false; var
>>>>>>>> searchBoxQueryURL
>>>>>>>> ="http://localhost:89/qgis-web-client-master/wsgi/search.wsgi?query=";
>>>>>>>> var searchBoxGetGeomURL
>>>>>>>> ="http://localhost:89/qgis-web-client-master/wsgi/getSearchGeom.wsgi";
>>>>>>>> When i try to search, i do not get anything! Is there any example for
>>>>>>>> searching setup?
>> __________ Information from ESET Mail Security, version of virus signature
>> database 9297 (20140116) __________
__________ Information from ESET Mail Security, version of virus signature database 9297 (20140116) __________
The message was checked by ESET Mail Security.
http://www.eset.com
