[Qgis-developer] Getting debug messages under windows
Matthias Kuhn
matthias.kuhn at gmx.ch
Mon Jan 20 01:42:36 PST 2014
Hi Olivier,
I don't work that much on Windows, so my experience may not cover all
cases.
In my experience, the easiest thing is to start the application from
VS. Do this, by right clicking the "qgis" project in the Solution
Explorer and click "Set as StartUp project". Then click the play button
(or Debug => Start Debugging). Now, the debug output should be in the
Output window of VS (If compiled with RelWithDebInfo). I think it is
also possible to attach Visual Studio to a running process, which
should help as well. Or there is a tool called DebugView which is
supposed to help, if VS is not installed.
Matthias
On Mon 20 Jan 2014 12:39:39 AM CET, Olivier Dalang wrote:
> Hi !
> While being a C++ newbie, I've been able to build QGIS under Windows
> by following the very precise information in the INSTALL file. Thanks
> to this, I managed to do already some very small contributions to the
> core.
> However, I've never been able to get debug output, which is refraining
> me from doing more... I've searched a lot, and found a lot of stuff,
> but nothing which worked or which made sense to me.
> It seems I have to change the cmake option : -D CMAKE_BUILD_TYPE=DEBUG
> (or RELWITHDEBINFO)
> I don't know what that is, nor how to change it. I've set the target
> to RELWITHDEBINFO in VCExpress (as stated in INSTALL), but that does
> not seem to be sufficient to get any output.
> I'm not even sure : is the output supposed to be printed in the
> command prompt from which I launched QGIS ?
> Thanks a lot in advance !
> Olivier
> Qgis-developer mailing list
