[Qgis-developer] On the fly simplication of point layers
A Huarte ahuarte47 at yahoo.es
Mon Jan 20 13:47:24 PST 2014
done:
https://github.com/qgis/QGIS/pull/1093
This patch hides the simplification rendering tab for point layers, now it is not supported (internally I am not trying to simplify point layers). Thanks Tim!
About if there is a use case for point simplification, I know one, (gvSIG  + dielmo open lidar) use it for load extreme big point layers as LiDAR LAS files are.
It know the code in java and I think easy migrate to QGIS. Basically, It ignore points by distance in a similar style as the current simplifier classes.
If you think good for QGIS I think but I can imlement it.
Alvaro
>________________________________
> De: Tim Sutton <lists at linfiniti.com>
>Para: qgis-developer <qgis-developer at lists.osgeo.org>
>Enviado: Lunes 20 de enero de 2014 21:29
>Asunto: [Qgis-developer] On the fly simplication of point layers
>Ok I guess you can see where I am going to go with this email :-) Is there any point to allowing users to simplify point layers? Alvaro, can your remove the point rendering tab in layer properties (and I guess check internally that you are not trying to simplify point layers)? Or is there a use case for point simplification that I am not getting?
>Regards
>Tim
>Tim Sutton - QGIS Project Steering Committee Member
>Please do not email me off-list with technical
>support questions. Using the lists will gain
>more exposure for your issues and the knowledge
>surrounding your issue will be shared with all.
>Irc: timlinux on #qgis at freenode.net
>_______________________________________________
>Qgis-developer mailing list
>Qgis-developer at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140120/ae0de832/attachment.html>
