[Qgis-developer] On the fly simplication of point layers
Tim Sutton
lists at linfiniti.com
Mon Jan 20 13:57:45 PST 2014
Hi
On Mon, Jan 20, 2014 at 11:47 PM, A Huarte <ahuarte47 at yahoo.es> wrote:
> done:
> https://github.com/qgis/QGIS/pull/1093
> This patch hides the simplification rendering tab for point layers, now
> it is not supported (internally I am not trying to simplify point layers)
> . Thanks Tim!
> About if there is a use case for point simplification, I know one, (gvSIG
> + dielmo open lidar) use it for load extreme big point layers as LiDAR LAS
> files are.
> It know the code in java and I think easy migrate to QGIS. Basically, It
> ignore points by distance in a similar style as the current simplifier
> classes.
Sorry I see my original email was not very clear - I meant if there was a
use case for point simplification as *currently implemented in master* - I
fully agree that filtering proximal points would be a good performance
booster, as would providing a point clustering capability.
> If you think good for QGIS I think but I can imlement it
That would be great! Thanks for your pull request.
Regards
Tim
> Alvaro
> *De:* Tim Sutton <lists at linfiniti.com>
> *Para:* qgis-developer <qgis-developer at lists.osgeo.org>
> *Enviado:* Lunes 20 de enero de 2014 21:29
> *Asunto:* [Qgis-developer] On the fly simplication of point layers
> Ok I guess you can see where I am going to go with this email :-) Is there
> any point to allowing users to simplify point layers? Alvaro, can your
> remove the point rendering tab in layer properties (and I guess check
> internally that you are not trying to simplify point layers)? Or is there a
> use case for point simplification that I am not getting?
> Regards
> Tim
> Tim Sutton - QGIS Project Steering Committee Member
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Irc: timlinux on #qgis at freenode.net
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140120/42b0946f/attachment-0001.html>
