[Qgis-developer] On the fly simplication of point layers
A Huarte
ahuarte47 at yahoo.es
Mon Jan 20 14:11:00 PST 2014
And, I wrote my reply wrong :-)
About point simplification, the strategy is no fetch in the featureiterator some points using a tolerance.
Do you think that I must try it ?
>________________________________
> De: Tim Sutton <lists at linfiniti.com>
>Para: A Huarte <ahuarte47 at yahoo.es>
>CC: qgis-developer <qgis-developer at lists.osgeo.org>
>Enviado: Lunes 20 de enero de 2014 22:57
>Asunto: Re: [Qgis-developer] On the fly simplication of point layers
>Hi
>On Mon, Jan 20, 2014 at 11:47 PM, A Huarte <ahuarte47 at yahoo.es> wrote:
>done:
>>https://github.com/qgis/QGIS/pull/1093
>>This patch hides the simplification rendering tab for point layers, now it is not supported (internally I am not trying to simplify point layers). Thanks Tim!
>>About if there is a use case for point simplification, I know one, (gvSIG + dielmo open lidar) use it for load extreme big point layers as LiDAR LAS files are.
>>It know the code in java and I think easy migrate to QGIS. Basically, It ignore points by distance in a similar style as the current simplifier classes.
>Sorry I see my original email was not very clear - I meant if there was a use case for point simplification as *currently implemented in master* - I fully agree that filtering proximal points would be a good performance booster, as would providing a point clustering capability.
>>If you think good for QGIS I think but I can imlement it
>That would be great! Thanks for your pull request.
>Regards
>Tim
>>Alvaro
>>>Para: qgis-developer <qgis-developer at lists.osgeo.org>
>>>Enviado: Lunes 20 de enero de 2014 21:29
>>>Asunto: [Qgis-developer] On the fly simplication of point layers
>>>Ok I guess you can see where I am going to go with this email :-) Is there any point to allowing users to simplify point layers? Alvaro, can your remove the point rendering tab in layer properties (and I guess check internally that you are not trying to simplify point layers)? Or is there a use case for point simplification that I am not getting?
>>>Regards
>>>Tim
>>>Tim Sutton - QGIS Project Steering Committee Member
>>>Please do not email me off-list with technical
>>>support questions. Using the lists will gain
>>>more exposure for your issues and the knowledge
>>>surrounding your issue will be shared with all.
>>>Irc: timlinux on #qgis at freenode.net
>>>_______________________________________________
>>>Qgis-developer mailing list
>>>Qgis-developer at lists.osgeo.org
>>>http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140120/3d88fbc8/attachment.html>
