[Qgis-developer] On the fly simplication of point layers
Tim Sutton
lists at linfiniti.com
Mon Jan 20 21:01:54 PST 2014
Hi
Sent from my mobile
On 21 Jan 2014 3:10 AM, "Mathieu Pellerin" <nirvn.asia at gmail.com> wrote:
> Also, that logic can only be applied for fully opaque point symbols. As
soon as you have a semi transparent symbol, the repetition of points over a
same map pixel does matter and needs to be preserved.
Agreed but in that case surely you would just disable simplification?
Regards
Tim
> On 21 Jan 2014 07:46, "A Huarte" <ahuarte47 at yahoo.es> wrote:
>> Ok, I will study it
>>> If you have time and inclination this would be great (note feature
freeze starts in 4 days). A logical starting may be to only return one
point per map pixel though I am not sure if you can push that kind of logic
over to provider side very easily.
>>> Regards
>>> Tim
>>>>> ________________________________
>>>>> De: Tim Sutton <lists at linfiniti.com>
>>>>> Para: A Huarte <ahuarte47 at yahoo.es>
>>>>> CC: qgis-developer <qgis-developer at lists.osgeo.org>
>>>>> Enviado: Lunes 20 de enero de 2014 22:57
>>>>> Asunto: Re: [Qgis-developer] On the fly simplication of point layers
>>>>> Hi
>>>>> On Mon, Jan 20, 2014 at 11:47 PM, A Huarte <ahuarte47 at yahoo.es> wrote:
>>>>>> done:
>>>>>> https://github.com/qgis/QGIS/pull/1093
>>>>>> This patch hides the simplification rendering tab for point layers,
now it is not supported (internally I am not trying to simplify point
layers). Thanks Tim!
>>>>>> About if there is a use case for point simplification, I know one,
(gvSIG + dielmo open lidar) use it for load extreme big point layers as
LiDAR LAS files are.
>>>>>> It know the code in java and I think easy migrate to QGIS.
Basically, It ignore points by distance in a similar style as the current
simplifier classes.
>>>>> Sorry I see my original email was not very clear - I meant if there
was a use case for point simplification as *currently implemented in
master* - I fully agree that filtering proximal points would be a good
performance booster, as would providing a point clustering capability.
>>>>>> If you think good for QGIS I think but I can imlement it
>>>>> That would be great! Thanks for your pull request.
>>>>> Regards
>>>>> Tim
>>>>>> Alvaro
>>>>>>> Para: qgis-developer <qgis-developer at lists.osgeo.org>
>>>>>>> Enviado: Lunes 20 de enero de 2014 21:29
>>>>>>> Asunto: [Qgis-developer] On the fly simplication of point layers
>>>>>>> Ok I guess you can see where I am going to go with this email :-)
Is there any point to allowing users to simplify point layers? Alvaro, can
your remove the point rendering tab in layer properties (and I guess check
internally that you are not trying to simplify point layers)? Or is there a
use case for point simplification that I am not getting?
>>>>>>> Regards
>>>>>>> Tim
>>>>>>> Tim Sutton - QGIS Project Steering Committee Member
>>>>>>> Please do not email me off-list with technical
>>>>>>> support questions. Using the lists will gain
>>>>>>> more exposure for your issues and the knowledge
>>>>>>> surrounding your issue will be shared with all.
>>>>>>> Irc: timlinux on #qgis at freenode.net
>>>>>>> _______________________________________________
>>>>>>> Qgis-developer mailing list
>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140121/2520b803/attachment.html>
